| Farmall & IHC Tractors Discussion Forum |
Topic: Re: Farmall H connecting rod alignment
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| C Brown
02-22-2013 05:36:29
70.89.49.129
when you say center to center, what exactly do you mean what all needs to go to machine shop? we are in Southern NJ where abouts are you |
[Reply] [No Email] | |
| CharlieNJ
02-22-2013 06:03:54
76.117.68.151
Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 05:36:29
| Your rods have two ends, a big end and a little end. You need the two ends to be true and square to each other. |
| C Brown
02-22-2013 05:47:20
70.89.49.129
| also i have another question, the old pistons in the tractor had a step in them, the new ones are flat top and symetrical except for one small notch on top of piston what way does that go appears to be fornt or rear, or also the stamping on the piston can face manifold or cam shaft size? |
| CharlieNJ
02-22-2013 06:17:41
76.117.68.151
Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 05:47:20
| It would be best for you to post a picture of both an old piston and a new one to tell you about the step and notch. I don't want to give you the wrong information, unless the "notch" is for valve relief, I would say it would go forward. As to the numbers, I would say towards the cam side. Better check that with someone who knows there. Regards, Charlie |
| C Brown
02-22-2013 05:53:27
70.89.49.129
| is it like this in video |
| CharlieNJ
02-22-2013 06:02:06
76.117.68.151
Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 05:53:27
| Yes, that's one way to do it |
| C Brown
02-22-2013 06:03:59
70.89.49.129
Re: Farmall H connecting rod alignment in reply to CharlieNJ, 02-22-2013 06:02:06
| are you in the southern nj area any shops you reccomend |
| C Brown
02-22-2013 06:34:52
70.89.49.129
Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 06:03:59
| how imperative is the alignment, i called a machine shop and they basically told me not to worry about it unless engine suffere major damage? Do alot of guys actually get this checked when yhey do rebuilds? |
| CharlieNJ
02-22-2013 06:42:52
76.117.68.151
Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 06:34:52
| Take his advice. The H motors isn't a high speed engine, and unless it was stuck and someone pounded the pistons out, I would say just put 'em back. But, depends on your level of perfection, and your wallet. When I install a rod and piston, I always turn the crank with a wrench, by hand, and feel for any binding, do it for each piston. Can also check the piston height with a dial indicator on a mount, to see if any are "short". |
| CharlieNJ
02-22-2013 06:24:02
76.117.68.151
| Yep, SJ, as far South as you can go. Where are you? Shops for what, parts, rod checking? |
| C Brown
02-22-2013 06:37:17
70.89.49.129
Re: Farmall H connecting rod alignment in reply to CharlieNJ, 02-22-2013 06:24:02
| Bridgeton, have all parts just needing shop for alignment |
| CharlieNJ
02-22-2013 06:45:08
76.117.68.151
Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 06:37:17
| I'm in Cape May. I have used Bridgeton Spring's machine shop several times. They are pretty good, give them a call too. Regards, Charlie |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
