TractorLinks.com
Show Parts for Model:
Re: Farmall H connecting rod alignment
CharlieNJ
02-22-2013 05:32:26
Rods are checked for center to center alignment on a "fixture device". An automotive machine shop would have one. It is not expensive to have them checked. If they need to be corrected, its a little more money. Sometimes the are honed, bushed, or bored back to specs.
Regards,
Charlie
C Brown
02-22-2013 05:36:29
 Re: Farmall H connecting rod alignment in reply to CharlieNJ, 02-22-2013 05:32:26
when you say center to center, what exactly do you mean what all needs to go to machine shop? we are in Southern NJ where abouts are you
CharlieNJ
02-22-2013 06:03:54
 Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 05:36:29
Your rods have two ends, a big end and a little end. You need the two ends to be true and square to each other.
C Brown
02-22-2013 05:47:20
also i have another question, the old pistons in the tractor had a step in them, the new ones are flat top and symetrical except for one small notch on top of piston what way does that go appears to be fornt or rear, or also the stamping on the piston can face manifold or cam shaft size?
CharlieNJ
02-22-2013 06:17:41
 Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 05:47:20
It would be best for you to post a picture of both an old piston and a new one to tell you about the step and notch. I don't want to give you the wrong information, unless the "notch" is for valve relief, I would say it would go forward. As to the numbers, I would say towards the cam side. Better check that with someone who knows there.
Regards,
Charlie
C Brown
02-22-2013 05:53:27
is it like this in video
CharlieNJ
02-22-2013 06:02:06
 Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 05:53:27
Yes, that's one way to do it
C Brown
02-22-2013 06:03:59
 Re: Farmall H connecting rod alignment in reply to CharlieNJ, 02-22-2013 06:02:06
are you in the southern nj area any shops you reccomend
C Brown
02-22-2013 06:34:52
 Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 06:03:59
how imperative is the alignment, i called a machine shop and they basically told me not to worry about it unless engine suffere major damage? Do alot of guys actually get this checked when yhey do rebuilds?
CharlieNJ
02-22-2013 06:42:52
 Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 06:34:52
Take his advice. The H motors isn't a high speed engine, and unless it was stuck and someone pounded the pistons out, I would say just put 'em back. But, depends on your level of perfection, and your wallet. When I install a rod and piston, I always turn the crank with a wrench, by hand, and feel for any binding, do it for each piston. Can also check the piston height with a dial indicator on a mount, to see if any are "short".
CharlieNJ
02-22-2013 06:24:02
Yep, SJ, as far South as you can go. Where are you? Shops for what, parts, rod checking?
C Brown
02-22-2013 06:37:17
 Re: Farmall H connecting rod alignment in reply to CharlieNJ, 02-22-2013 06:24:02
Bridgeton, have all parts just needing shop for alignment
CharlieNJ
02-22-2013 06:45:08
 Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 06:37:17
I'm in Cape May. I have used Bridgeton Spring's machine shop several times. They are pretty good, give them a call too.
Regards,
Charlie
