Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Farmall H connecting rod alignment
[Return to Forum]
C Brown
02-22-2013 05:00:49
70.89.49.129
im putting together a farmall h engine with my shop class, we are going through the manual and the section with connecting rods states that connecting rods need to be aligned, my question is how to i check proper alignment to not have them cocked
[Reply]   [No Email]
D Slater
02-22-2013 07:12:56
184.15.17.95
 Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 05:00:49
If the engine didn't have stuck pistons with the rods pounded on when removing them. Also if the piston skirts and bearings look normal on how they normaly wear if okay. I wouldn't worry to much about the rods in stock low speed H engine. Unless new piston pin bushings are put in out of square. If having a machine shop install the bushings you may as well have the rods checked. After cleaning the rods up its not a bad idea to bolt the caps on and torque the bolts and check the big end size without bearings. Also check the pin bushing size and out of round if reusing. My 2 cents.
[Reply]  [No Email]
C Brown
02-22-2013 07:34:51
70.89.49.129
 Re: Farmall H connecting rod alignment in reply to D Slater, 02-22-2013 07:12:56
ok i put new sleeves in it and replaced main bearings and lower rod bearings
[Reply]  [No Email]
CharlieNJ
02-22-2013 05:32:26
76.117.68.151
Rods are checked for center to center alignment on a "fixture device". An automotive machine shop would have one. It is not expensive to have them checked. If they need to be corrected, its a little more money. Sometimes the are honed, bushed, or bored back to specs.
Regards,
Charlie
[Reply]  [No Email]
C Brown
02-22-2013 05:36:29
70.89.49.129
 Re: Farmall H connecting rod alignment in reply to CharlieNJ, 02-22-2013 05:32:26
when you say center to center, what exactly do you mean what all needs to go to machine shop? we are in Southern NJ where abouts are you
[Reply]  [No Email]
CharlieNJ
02-22-2013 06:03:54
76.117.68.151
 Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 05:36:29
Your rods have two ends, a big end and a little end. You need the two ends to be true and square to each other.
[Reply]  [No Email]
C Brown
02-22-2013 05:47:20
70.89.49.129
also i have another question, the old pistons in the tractor had a step in them, the new ones are flat top and symetrical except for one small notch on top of piston what way does that go appears to be fornt or rear, or also the stamping on the piston can face manifold or cam shaft size?
[Reply]  [No Email]
CharlieNJ
02-22-2013 06:17:41
76.117.68.151
 Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 05:47:20
It would be best for you to post a picture of both an old piston and a new one to tell you about the step and notch. I don't want to give you the wrong information, unless the "notch" is for valve relief, I would say it would go forward. As to the numbers, I would say towards the cam side. Better check that with someone who knows there.
Regards,
Charlie
[Reply]  [No Email]
C Brown
02-22-2013 05:53:27
70.89.49.129
is it like this in video
[Reply]  [No Email]
CharlieNJ
02-22-2013 06:02:06
76.117.68.151
 Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 05:53:27
Yes, that's one way to do it
[Reply]  [No Email]
C Brown
02-22-2013 06:03:59
70.89.49.129
 Re: Farmall H connecting rod alignment in reply to CharlieNJ, 02-22-2013 06:02:06
are you in the southern nj area any shops you reccomend
[Reply]  [No Email]
C Brown
02-22-2013 06:34:52
70.89.49.129
 Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 06:03:59
how imperative is the alignment, i called a machine shop and they basically told me not to worry about it unless engine suffere major damage? Do alot of guys actually get this checked when yhey do rebuilds?
[Reply]  [No Email]
CharlieNJ
02-22-2013 06:42:52
76.117.68.151
 Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 06:34:52
Take his advice. The H motors isn't a high speed engine, and unless it was stuck and someone pounded the pistons out, I would say just put 'em back. But, depends on your level of perfection, and your wallet.
When I install a rod and piston, I always turn the crank with a wrench, by hand, and feel for any binding, do it for each piston. Can also check the piston height with a dial indicator on a mount, to see if any are "short".
[Reply]  [No Email]
CharlieNJ
02-22-2013 06:24:02
76.117.68.151
Yep, SJ, as far South as you can go. Where are you? Shops for what, parts, rod checking?
[Reply]  [No Email]
C Brown
02-22-2013 06:37:17
70.89.49.129
 Re: Farmall H connecting rod alignment in reply to CharlieNJ, 02-22-2013 06:24:02
Bridgeton, have all parts just needing shop for alignment
[Reply]  [No Email]
CharlieNJ
02-22-2013 06:45:08
76.117.68.151
 Re: Farmall H connecting rod alignment in reply to C Brown, 02-22-2013 06:37:17
I'm in Cape May. I have used Bridgeton Spring's machine shop several times. They are pretty good, give them a call too.
Regards,
Charlie
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
