TractorLinks.com
Show Parts for Model:
Re: Duals question?
The tractor vet
02-21-2013 15:17:52
Well it can be set up with the dish out and the rims set in , now depending on your row crop width that will tell ya what side of the wheel the dogs go on and where your dual hubs will set If your tryen to do a straddle dual set up . And with running a hub mount now you can run the same air pressure on the duals as the tractor. With Clamp on duals running the same pressure i have seen a lot of busted axle clamp bolts . So if your doing a 30 inch row the center of the tire should be 30 inch from the center of the PTO to the center of the tread and thirty inches to the center of the dual .
