| Farmall & IHC Tractors Discussion Forum |
Topic: Knew I should have checked yesterday...
[Return to Forum]
| Author |
[Modern View]
| IH fan
02-21-2013 11:16:56
108.246.52.113
... old 240U had leaked all the gas out and the spare gas is in the shed where I'll need to shovel some snow to get to it. Wife has given me orders to not shovel due to not having the best heart around, but I'll do a little at a time and get there. Cranked over good, but wouldn't start. I had the gas valve under the tank shut off, but it leaked out somewhere anyway.
Had over 1/2 tank of gas a month ago when I started it, but not today. Have a good foot of heavy wet snow, more than I figure the AWD SUV will go through and the city has been through and piled it up at the street.
Good thing is we really needed the moisture and this is wet. It will be like watering and fertilizing when it melts. |
| Baelee05
02-22-2013 06:35:27
12.192.13.220
Re: Knew I should have checked yesterday... in reply to IH fan, 02-21-2013 11:16:56
| If you haven"t been able to see any visual signs of leakage you are being ripped off. If you lost a half tank you should be able to see clear signs of it on the tractor such as peeling paint. I think you probably have a thief in your midst. Get one of those cheap trail cams and set it up somewhere close and I"ll bet you"ll find out where your gas is going. |
| IH fan
02-22-2013 09:42:35
108.246.52.67
Re: Knew I should have checked yesterday... in reply to Baelee05, 02-22-2013 06:35:27
| Baelee05 said: (quoted from post at 09:35:27 02/22/13) If you haven"t been able to see any visual signs of leakage you are being ripped off. If you lost a half tank you should be able to see clear signs of it on the tractor such as peeling paint. I think you probably have a thief in your midst. Get one of those cheap trail cams and set it up somewhere close and I"ll bet you"ll find out where your gas is going. |
Think I'll start parking it in back after this snow is gone. Only evidence of leaks is hydraulic fluid. I should take the pump off and put in a new shaft seal... that's the worst leak I have. I have added about 2 1/2 gal. since I bought the tractor about 7-8 years ago, but most within the last 2 years so it's getting worse.
added: Amazing what a little gas will do. Fired right up after dumpung a 5 gallon can in her. opened up the driveway, not pretty, but should be able to get either vehicle out. The old '95 F-150 is sitting where it will have to melt first, but it pretty much stays hooked to the utility trailer and I won't need it for a while, but my AWD Hyundai Santa Fe and wife's LS should get out okay. We have a circle drive about 180' off the road and only opened one side as it's supposed to get into the 40s by Sunday and it should melt off.
This post was edited by IH fan at 12:05:04 02/22/13. |
| Allan In NE
02-21-2013 17:29:38
148.66.88.254
| | Leaky fuel tank and you put the tractor inside a shed........... You scare me! :>) Allan |
| IH fan
02-21-2013 23:32:57
108.246.52.113
Re: Knew I should have checked yesterday... in reply to Allan In NE, 02-21-2013 17:29:38
| Quoting Removed, click Modern View to see
I wish my shed was big enough to put the tractor inside. Got a couple of 5 gallon cans in the shed with the gas for tractor, garden tractor, mowers or whatever. Shed is only 12x16 with an 8x12 "lean too" extention. Poor old 240U has to sit outside. |
| John LaBoyteaux
02-21-2013 14:32:51
63.80.39.202
| Those under tank valves will leak around the packing or around the glass bowl seal even when off. Should be some evidence of dripping however on or below the tractor. Even if those spots are not leaking, the valve may not close completely and leak through the carburetor. |
| leej
02-21-2013 12:18:40
216.73.235.175
| Are you sure it leaked out? Or did someone need a little bit. Mine was drained by a snowmobiler who smoked, I don't. He left tracks. ggp |
| IH fan
02-21-2013 15:59:08
108.246.52.113
Re: Knew I should have checked yesterday... in reply to leej, 02-21-2013 12:18:40
Someone else mentioned that, and after thinking about it for a while, it could be the case. It is parked in my front yard, next to a neighbor I don't trust. I had 1/2 tank or better missing once before and thought it was leaking, even though there was no real evidence of a leak. That's when I started shutting off the valve. Then no more leaks until this time, after running the tractor about a month ago, and filling the loader hydraulics which had leaked down some, and checking to be sure there was at least 1/2 tank of gas. I know there is a leak in the loader pump shaft seal and a small leak near the PS Char-Lynn torque generator, but never noticed evidence of a gas leak. With a foot or better of snow now, I wouldn't see that now anway. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
