Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Trickle chargers, batteryminders?
Jon Hagen
02-20-2013 19:04:35
The batteryMINDer, atleast the little $40, 1.3 amp model will slowly desulfate a sulfated battery, although it can take months on a severly sulfated one. I had one in a rolled over Hough payloader I bought. Big 12V battery that laid upside down for several hours when the machine rolled and killed the operator.
All the electrolyte drained out while it laid upsidedown then the battery and machine laid in a salvage yard for a year, so the battery was sulfated almost beyond hope with the plates exposed to air for a year.
I bought the machine , refilled the battery with new electrolyte and put it on the desulfator. after a week it would put out enough to engage the starter and roll the engine about 1/2 turn. After a couple more weeks it would start the engine. After several months of use and desulfating it would crank much longer than the starter could safelt take. I would guess that battery regained 90% of new capacity.
bottom line, is that a charger with the desulfate feature will slowly remove the sulfation from a sulfated but otherwise healthy battery.
It in no way will magically restore a shorted or worn out battery.
I see the latest BatteryMINDer model now has temperature compensation so it better maintains full charge without overcharging in temps from -40 to +130.
George Marsh
02-21-2013 09:22:59
 Re: Trickle chargers, batteryminders? in reply to Jon Hagen, 02-20-2013 19:04:35
Jon,
A year ago, my GMC was 5 years old. The dealer told me my battery had a full charge but failed the load test. That's when I bought the batteryminder. It can charge gel, flooded and AGM batteries at 2,4 & 8 amp rate. My truck had the original Delco Agm. I bought a new battery for the truck and put the batteryminder on the old battery for 3 months. No change in battery's condition.
On other batteries, it may take weeks or a few days to run through the complete cycle, but when it's done, the charger goes in to a default, gel and 2 amp light flash.
I do have a mower battery made on 2008. It's rated at 340 cca. My battery conductive tester shows it's bad. Battery makes 240 cca. My batteryminder has spend a lot of time on this battery the past winter with no noticeable change in the cca.
However, you can buy a new cheapie mower battery rated at 200 cca. So I've learned to buy the bigger battery and even though it's shows bad, it can still out preform a new battery. I will install the 2008 battery in a mower that is close to home, so I can keep an eye on it.
My farmall, IH C, has a very old 12v battery, can't say just how old, but old. It has one cell that is weak, battery conductive testor shows battery is bad. However when you hit a 6v starter with a sick 12v battery, the starter flips the engine over like it's a healthy battery. Had I not used a hydrometer or the battery conductive testor, I would think the batteryminder was doing GREAT. I just moved the batteryminder to the IH C this morning.
The way I feel about the batteryminder it won't reverse the aging process of a battery, but hopefully it will slow down the aging process.
I have a very old 12v battery on the Jubilee too. Same as the IH C. An old wimpy 12v can move a 6v starter faster than a good 6v battery.
You slow down the aging process of a battery by keeping it fully charged even if you use a trickle charger. Just don't over charge it or you will damage it.
Just my $.02 worth.
I won't spend $100 on another batteryminder.
I like my battery conductive tester. It lets you know your battery is about to take a dump, so you can do something before you get stranded.
George
John G. Hasler
02-20-2013 19:26:34
> I see the latest BatteryMINDer model now has > temperature compensation
Disappointing that they haven"t all always had it. That"s an essential feature: it isn"t much of a "minder" without it. It"s also trivial to implement.
