Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: A Farmall Moldboard Lift
[Return to Forum]
Mo in NE Tex
02-20-2013 17:29:02
71.96.141.230
Is the lift rod that goes from the lift lever to the rear to the plow supposed to slide inside the pipe/sleeve that is used to lift the plow. From everything I can see in the books it"s two separate pieces and the book says to push the lever all the way forward when plowing. Mine is currently frozen into one piece and I can see where it should move freely to allow the plow to move up and down on it" own.
[Reply]   [No Email]
Curt Cooke
02-20-2013 18:44:51
68.61.51.221
 Re: A Farmall Moldboard Lift in reply to Mo in NE Tex, 02-20-2013 17:29:02
Should float! Technically that lever only lifts, depth is controlled by the lever in front of you which controls the front of the plow beam. The right hand lever lifts the plow and must float when the plow is in the ground to work as designed
[Reply]  [No Email]
gene bender
02-20-2013 17:43:51
67.55.226.151
That rod realy wouldnt need to be so it could float as you do pull the lever back to lift the plow. I would guess they had that part in two pieces for assy. Yourlever is for adjusting the depth of the plow. Does yours have the guage wheel?
[Reply]  [No Email]
Mo in NE Tx
02-20-2013 19:28:48
71.96.141.230
 Re: A Farmall Moldboard Lift in reply to gene bender, 02-20-2013 17:43:51
Gene, I picked up the lift lever that mounts on the right side of the floor board. I also have the depth lever that mounts on the side of the trans tunnel. No gauge wheel. I realize the depth is controlled by the angle of the point and not the lift lever. Back a few years ago,(quite a few), we used to plow with a walking plow behing a team of mules and you had to learn how to set the plow up so not to work yourself to death. After a while we could plow this heavy clay with just one hand after we learned not to fight the plow. The rod that goes under the seat to the plow should not put downward pressure on the plow is how I see the lay-out in the manual and should be free to float with the beam. My rod is frozen solid and I just needed confirmation that it should be free to float.
[Reply]  [No Email]
stumper
02-20-2013 22:31:06
24.247.104.181
 Re: A Farmall Moldboard Lift in reply to Mo in NE Tx, 02-20-2013 19:28:48
yes that rod need to be free ,in case of up presure (rocks and such)it can rise without damage to parts ,stumper
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
