Morning All,
Just wanted to let you all know and thank you for your help fixing the stalling on my ih 454.
Some suggested to check for fuel . So when it warned up enough I crawled around this tractor till i found the sediment bowl and shut offs.
I am used to hte old tractors where every thing is in plain sight and easy to access.
Found bowl and shut offs back at the tank between tank and axle housing. So I took off the glass cleaned gunk out let fuel run out and put back together. now it runs like it used to.
Thanks to all that responded I really like it that so many are willing to share their expertice
to help others . Now if i can find the voltage regulator I can try to reset polarity and we should be good to go .
Again Thank You,
Harry
Again Thank You,
Harry
