656 Hydraulic Question
Just bought a 656 utility gear drive. Bought it from a dealer, it was a rough trade in. When they traded it in, all the hydraulics worked OK. Now they dont work at all. No steering or loader. PTO does turn on/off. Weird thing is when when we were loading it backwards, when it was on our steep ramps, the hydraulics started to work a little...? The steering seemed to work ok?
Anyone got any ideas??
First and simplest is to check the fluid level in the transmission/hydraulic resivoir. Make sure it"s at least full of Hy-Tran or equvalent. I usually run a bit over full. You may have to run it a bit to let the system refill and work any air out if it has been sitting for any length of time.
Sounds like the center of pressure plate tore loose or the splines are worn out. The pressure plate drives thr pumps and PTO.
