Doug Wi
Is there an after market source for tractor windshields or are the dealers the only source?Just got a 1594 and when it arrived the windshield was shattered.Must have either picked up a rock or hit a bird while traveling. seller is going to pay for it, but i have to track down the part. Thanks for any info.
If it is flat any glass shop should be able to cut one. Did you mean shattered as in little pieces? You should have laminated safety glass in a windshield. Sounds like it was a cheap replacement herculite glass.
Its not flat , has a slight curve in it .So it has to be the right one. But it is safty glass. Still in place but cracked like safty glass does. Can hardly see through it. Called a couple of local auto glass shops and they said their only source would be the dealers. thought maybe some of you guys would know something they didn't. Thanks
check with an a&i parts dealer or online they were the most reasonable on the windshield for my 186 IH I dont know if they have the one you need but the list was long
