Anonymous-0
I just bought the nicest farmer owned TD-6 dozer.1953,gas/diesel,original hour meter,less than 2800 hrs.Even the dash light works. Awesome. Not a weld anywhere. Beautiful. But I don"t have any books yet. So I need to know, does the fuel injector pump need oil in it anywhere? If so. Same as the engine uses? Also has the original headlights/rear work light w/the screens and large brush guards,perfect. What bulb do these take? Thanks, Bob
yes it uses the same oil as the engine. holds about a cup of oil. drain is the 1/8 pipe plug at btm. fill from top where flip cover is till runs out petcock above drain. not sure on bulb #.
(quoted from post at 16:32:02 02/16/13) yes it uses the same oil as the engine. holds about a cup of oil. drain is the 1/8 pipe plug at btm. fill from top where flip cover is till runs out petcock above drain. not sure on bulb #.
Yep what he said, but this thread is useless without pictures. :lol:
found one in ohio like you discribed in a scrapyard here is a picture thanks rob
