Farmall SH Starter
Any body have a 2-bolt starter for an H or SH they would want to part with or part out? Looking for a nose cone housing as mine has a bolt flange broken. I also need the front bolt from the large drive spring. Looks like a 3/8-24 with a large, thin head and about 3/4" long. Mine worked its way out and got wedged in the housing and ground the threads off. Starter worked great before this happened! I also need a brush cover band.
This is for a 1953 Farmall SH, stage 1. Thanks!
I probably have a bad starter in my shop since I found out a long time ago the starter off a B or A will bolt on an H and I have one or 2 starters off Bs in my shop
I have a starter off a 1953 super h for sale. I thought they were a 3 bolt flange with the starter button on top of the starter.
Have the parts for a H or M but the late H and SH shows a different drive housing part number for the 2 bolt starter with switch on top. Don't have a stage one starter to compare. May just be the way the motor is clocked to the drive end.
