Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Regular mag, how much spark?
oldiron29
02-15-2013 18:36:16
Jim, Should have spark that could jump 1/4". Are the primer cups closed? Does not take much to flood a Regular. Most of mine will only take half crank with choke on. How have you set your timming? Mag should snap at TDC. There is a sweet spot where they like to be. when you get it right most will take 1 crank choke and start on the second crank. How many turns have you opened the carb. main jet? The knob on top of the carb. oldiron29
Fixerupper
02-15-2013 18:58:01
 Re: Regular mag, how much spark? in reply to oldiron29, 02-15-2013 18:36:16
The mag snaps at TDC or maybe 1/2 degree late with the advance just above shutoff. I'll check the primer cups tomorrow. Knob is cranked probably two turns, I've been playing with it so I'm not sure where it's at exactly . Where should it be? My I&T manual is about as useful as toilet paper when it comes to carb adjustment and timing. I do have a repro owners manual and it is a little more helpful with timing but not much. What could cause the weaker spark? Armature? Points were removed and cleaned and look good. As I understand the coil is in the armature and a rebuilt is in the $150 range if I remember right. My first instinct tells me it acts like weak spark. Jim
oldiron29
02-16-2013 04:00:25
 Re: Regular mag, how much spark? in reply to Fixerupper, 02-15-2013 18:58:01
kirk is right, That why guys switch over to the F-4 mag. Less expensive to fix. oldiron29
