I just installed a Pertronix ignition in my Super M and also put on the recommended "Flame Thrower" coil. It is a 12v negative ground. I followed the instructions closely and now the tractor won"t start. Turns over, but won"t fire at all. I hooked on the old coil and the result is the same-no start.
Anyone have any experience with the electronic ignitions? Maybe the igniter module is bad. Is there a way to test the module? Voltage to the coil is very good. Called the help number, but they are closed today, which I thought they probably would be.
