TractorLinks.com
Show Parts for Model:
Re: 706 steering wheel
pete 23
02-10-2013 20:37:19
Supposed to be a nut holding wheel on. Then two 1/4 inch or 5/16th inch fine threaded tapped holes for puller. The best puller I ever found, and I have a regular wheel puller, is a half inch thich piece of iron, about 1 1/2 in wide,just long enough to fit inside of wheel. Drill two holes the distance holes in wheel are apart. Now, those threads will strip real easy so get a bolt long enough to go through the iron and bottom in threads. Add washers under bolt head as needed to accomplish that. Tighten bolts cautiously, tap gently on iron over shaft,add thin washers and continue. Use penetrating oil on shaft. Pulled many a wheel that way rusty and new.
Kirk Affeldt
02-11-2013 19:17:38
 Re: 706 steering wheel in reply to pete 23, 02-10-2013 20:37:19
Pete 23, Could you share photo of your steering wheel puller? It sounds interesting and very simple. I will have to replace my 706 steering wheel someday soon. Thanks!
pete 23
02-12-2013 10:24:04
 Re: 706 steering wheel in reply to Kirk Affeldt, 02-11-2013 19:17:38
Not good with pictures. It is just a chunk of iron. Over the years I have lost and made different ones but the first one I made was to pull steering wheel on my 55 plymouth so it is kind of universal. Maybe 2 l/2 inchs long, 1 1/2 wide, l/2 inch thick and drill two holes to match holes in steering wheel.
