| Farmall & IHC Tractors Discussion Forum |
Topic: 666 alternator
[Return to Forum]
| Author |
[Modern View]
| Bradiniowa
02-10-2013 13:00:00
184.63.19.28
Problem has been going on for awhile. If the tractor sets two or three days the battery is completely drained or nearly so. Had two mechanics tell me how to check for a draw but both methods showed nothing. Tried disconnecting battery which stopped the draining, then left battery connected and disconnected alternator. This also stopped the draw. Question is, what is wrong with the alternator and is it repairable or need replaced? |
| gbs
02-10-2013 19:39:46
71.51.250.1
Re: 666 alternator in reply to Bradiniowa, 02-10-2013 13:00:00
| if yours has a 10 si delco unplug the 2 wire plug check for voltage at the plug itself with ign switch off,one should have voltage all the time the other only when ign. is on, it's the exciter wire for the regulator, if voltage is present with the switch off it will keep the alternator switched on killing the battery grave yard dead, some tractors use an oil pressure switch to control it not sure which one yours uses |
| Brownie 450
02-10-2013 15:36:13
66.43.241.198
| Can't get much closer to the arctic circle than Volga. We're down South of Wilton. If you were closer, I'd stop by to help. |
| Brownie 450
02-10-2013 14:19:45
66.43.241.198
| Where are you housed up at in Iowa, Brad? |
| Bradiniowa
02-10-2013 15:01:37
184.63.19.28
Re: 666 alternator in reply to Brownie 450, 02-10-2013 14:19:45
| Near Volga (NE Iowa). How about you? |
| karl f
02-10-2013 13:38:06
172.129.63.66
| | check under the dash at the terminal junction block and also inspect the cigar lighter closely. Rusty lighters can develop a short between + and - terminals internally. Rust and chaff at the junction block also cause a short to ground. karl f |
| Brownie 450
02-10-2013 13:17:35
66.43.241.198
| Try disconnecting the large terminal first & see if there is a spark upon the disconnecting. If you have a small ammeter, put it between the disconnected wire & the large terminal on the Alt. Read current draw--if any. If there is small draw here, rectifier is bad in alt. If no trouble here, re-connect wire, & pull out 2-terminal connector on alt. & see if battery discharges. If no discharge on batt. now, regulator is probably at fault. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
