A Farmall with one bottom plow
Here are pics of the "A" Farmall with the plow finaly attached (I think). Gene Bender, does this look right now to use the manual lift? I sure did like the leveling feature on the power lift unit, couldn"t figure out how to make it work without having to cut the power lift arm off and I didn"t want to destroy that as it will work on any of the later models with hydraulics.
And before anyone from the CP comments, yes the right tire is on backwards. I might get stuck and want to back out LOL!!
Looks like some one took a plow for C or B Allis Chalmers and made it to work on your A. All of the plows I have seen and Used on model A used the draw bar turned backwards to hitch front of plow and used a chain from the rockshaft to lift it.
Looks like they done good work on building it.
You didnt show the lift lever. Ihave never seen one with the shift lever and its not in my parts book. The other rockshaft assy you have would work if it had the link for the lift handle.
Gene, I don"t have the lift lever, that"s the only thing I"m missing now. If you get some good weather and time, could you check and see if you do have one?
As Im sure that will work, it is not the correct setup. I do not have very good pictures but, I will post them next month when I hook mine up. For now, this is what it looks like on the A , non super.
