1944 Farmall H charging system
I have a 1944 farmall H and was wondering if on the light switch if there was a position for charging the battery. When I turn the switch on it shows on my ampmeter that the battery is charging. Any help/knowledge about this would be appreciated. Thanks
If it has the LHDB light switch, L is Low Charge, H is High Charge, and if lights are on Dim or Bright its in High Charge.
If it has a Voltage Regulator and just a switch for lights ONLY, the VR regulates the charge automatically..
My Troubleshooting Procedure is below
John T
John Ts Troubleshooting
