Wide=front end
TV Iron
I have a BF Avery tractor (20 HP) that has an International Harvester (Farmall) front end. I can not find any numbers on the unit that would identify what tractor it came off from. The only thing that may help would be that it has two rubber bumpers (one on each side close to the radiator grill) of the main round tube that supports the axle and wheels. Any help identifying the IH tractor that it would fit would be helpful.
I know that the front pedistal for a BF Avery could be bolted to a C series bolster. My Uncle did put a single wheel for an Avery on his 240 but I am not sure how much he had to alter the bolster. If the wide front was for a C series it will have the tie rods in the front of the round tubes.
That wide front would be the same for C, Super C, 200, 230 and 240. Might also be the same as on a 504.
