Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Brakes on Super A
gene bender
02-09-2013 03:08:25
Remove the final drives and the bands are rite there. I remove the wheel then use a cherry picker to remove the final as its heavy. Important to have the chassis secured to keep it secure. You will want a cherry picker as the drivers whell has the cast center and is very heavy.If the seals are leaking the outer ones can be replaced by removing the drum and taking the diff shaft out thru by removing the plate on the final.. Mite also be a good time to replace the lube in the final by removing the bottom housing on the final then replace with 90wt thru the plug located at the bottom of the finaljust above the pan you removed to replace the lube.
