Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: A Blue tractor problem
[Return to Forum]
Leon Torkelson
02-08-2013 14:11:05
50.33.38.32
I have a Ford 3600, a misfit around 12 farmalls. I am having a problem with the ignition switch. It starts and runs as long as I hold the key in the start position, whenI let the key go back to the run position the tractor it quits like it was shut off. I changed the switch but it acts the same. any ideas or previous problems like this. Thanks in advance.
[Reply]   [No Email]
cchigg
02-08-2013 17:11:53
76.118.14.146
 Re: A Blue tractor problem in reply to Leon Torkelson, 02-08-2013 14:11:05
sounds like a bad ballast resister if it will run with the key in the start position and when you let go to the run position it will shut off like you turned the key off.don't bypass it or it will fry the points.
[Reply]  [No Email]
Janicholson
02-08-2013 15:28:29
12.222.76.199
Some Fords may have a resistor wire in the ignition circuit rather than a discrete component. If when the ignition is turned to ON, there is no voltage at the coil, and you find no object as a resistor, it could be the wire itself. Jim
[Reply]  [No Email]
Bob M
02-08-2013 14:45:04
74.67.191.60
Leon - Most likely the problem's a failed (burned out) ballast resistor.
The resistor is wired between the ignition switch and the coil and gets bypassed when the ignition switch is in "start". Thus the engine fires when cranking but quits when you release the switch back to "on".
[Reply]  [No Email]
old
02-08-2013 14:20:38
209.86.226.11
I was going to answer you in the ford forum but since I see it here I will here. Good chance the ballast resister is bad since it starts and runs as long as you hold the switch. Many engines are set up to by past the resister so as to give a stronger spark for starting
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
