| Farmall & IHC Tractors Discussion Forum |
Topic: Re: SC Governor Removal
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| gene bender
02-05-2013 16:32:47
67.55.226.151
Only thing helpful in removing is loosen the fan down for a little more room to remove the gov. Before you remove the gov set the linkage going to the carb. With engine off remove the pin on the gov arm going to the carb. Now open the throttle pin should go back in holding the carb fully open. Adjust the clevis so it does. Be careful turning the clevis so you dont bend the carb lever. Mite need to secure the rod with a vicegrip to avoid bending carb lever. Throttle response should be ok IF the input lever on the gov doesent have too much wobble. That can be fixed by re-bushing that lever. In that case the gov housing will need to be removed. I have fixed a bunch of them by line boring to 5/8 and installing a 1/2x5/8 brass bushing. If you do need to remove the gov check the thrust bearing it could be bad also. Do not remove the gear as it times the Mag/Dist there is no need to remove it. |
| Bud W
02-05-2013 16:54:46
70.242.114.188
Re: SC Governor Removal in reply to gene bender, 02-05-2013 16:32:47
| Thanks Gene I will give it a try. My main problem is when I set the throttle down as low as possible and start the engine it will race. When I grab the carb rod and push it forward as much as possible it slows down but not to what I would consider a slow idle. I have a few things to try before tearing the Governor down.Bud |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
