TractorLinks.com
Show Parts for Model:
Re: SC Governor Removal
Janicholson
02-05-2013 15:15:48
If it has about 1/2 of the throttle travel doing nothing, it is about normal. Adjusting the length of the rods to the governor such that at full lever travel, the governor lever is all the way is about all that can be adjusted. If it is jerky of pulses in RPM, and carb adjust won't fix it, then governor rebuild is a good idea. I am glad the unit actually runs!!!!. Jim
Bud W
02-05-2013 16:30:17
 Re: SC Governor Removal in reply to Janicholson, 02-05-2013 15:15:48
Jim
Actually I'm having a problem in getting it to idle down.With the throttle set as low as possible the tractor will race.When I walk around and pull the carb rod forward it will settle down a bit but still runs too fast.I will work on those rods before blasting into the Governor since I've already been there and done that. Again I really appreciate your help.I feel like I'm slowly learning a lot.Bud
