TractorLinks.com
Show Parts for Model:
Re: A Farmall Breaking Plow Setup
El Toro
02-05-2013 10:36:43
Here's my Farmall A with the moldboard plow. Hal
PS: If I remember right I think that drawbar had to be reversed. There are pics in the archives on this forum that show the A with the mounted plow from the rear. I have them stored somewhere on My Documents.
CNKS
02-05-2013 12:37:34
 Re: A Farmall Breaking Plow Setup in reply to El Toro, 02-05-2013 10:36:43
Probably mounted similarly, but what he calls a "breaking plow" is probably a disk plow likely with 2 disks, very common in S Texas and other southern states where moldboards were not used.
Mo in NE Tx
02-05-2013 15:19:55
 Re: A Farmall Breaking Plow Setup in reply to CNKS, 02-05-2013 12:37:34
Not a disk, one botton moldboard, beam is nerly as long as the tractor. I"ll try to get it out in the open to get a pic of it and post tomorrow.
CNKS
02-05-2013 19:56:22
 Re: A Farmall Breaking Plow Setup in reply to Mo in NE Tx, 02-05-2013 15:19:55
OK, I have never heard a moldboard called a breaking plow, only disk plows-but I don't know the terminolgy from all the US or elsewhere either.
El Toro
02-05-2013 15:59:10
Do you have the levers on your tractor for tilting the plow point and for lowering and raising the plow? I had never installed that plow on a Farmall A . We never had an A. They used pull type plows. I asked the local IH dealer back then in 1976 if they knew how. None of them had ever installed that plow. My plow had all the brackets on it and it wasn't that hard to mount. Hal
Mo in NE Tx
02-05-2013 16:14:21
 Re: A Farmall Breaking Plow Setup in reply to El Toro, 02-05-2013 15:59:10
I have the levers for the cultivators and planter, I'll have to get it all out again. It does have the leveling (side to side) leaver. Looks like it hooks to the rear or the tractor where the drag out plows hook up. I'll get it out tomorrow and get some pics posted.
gene bender
02-05-2013 16:43:21
 Re: A Farmall Breaking Plow Setup in reply to Mo in NE Tx, 02-05-2013 16:14:21
Those levers are different and the levelling is done with a crank on the rockshaft assy. I have that assy if you need it.319-430-3907
