TractorLinks.com
Show Parts for Model:
Re: Coil External Resister
Janicholson
02-04-2013 18:28:12
Dear John With no disrespect, there are no internal resistors in coils. The 12volt for use with no external resistor does not imply that there is an internal resistor. There is not. It is just wound such that it can operate on full 14.2 volts of an operating charging system.
Bud's tractor has a 6 volt coil of unknown operational status. (we think it is bad)
he needs either a new ballast resistor, and a new coil, or a new coil only. If he purchases a 12v No external resistor required coil he can dispense with the ballast resistor all together.
That is part number MPE IC 14SB (no resistor required 12v. Jim
John G. Hasler
02-04-2013 18:52:54
 Re: Coil External Resister in reply to Janicholson, 02-04-2013 18:28:12
> there are no internal resistors in coils. The > 12volt for use with no external resistor does > not imply that there is an internal resistor. > There is not. It is just wound such that it can > operate on full 14.2 volts of an operating > charging system.
I know that, but the manufacturers often describe them as if they do have an internal resistor. It"s simpler to accept that description than to explain that they are wound with very fine wire.
> If he purchases a 12v No external resistor > required coil he can dispense with the ballast > resistor all together.
That"s what I thought I said.
