Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Need advise to get bearing out
Dennis K (WA)
02-04-2013 12:24:05
Hi Paul,
Put a block of wood on the floor so you don't damage the splines, stand it up vertically with bull gear end down. Pick it up a bit and drop it on the splined end and the shaft with outer bearing will slide out.
Inside the housing will be full of grease from bearing being greased for many years. Once the shaft is out you can go down through the housing and drive out the other bearing and then the seal.
good luck
paul shuler
02-04-2013 16:18:18
 Re: Need advise to get bearing out in reply to Dennis K (WA), 02-04-2013 12:24:05
And what is the best way to put the bearings back in? Will i need a press or can i tap them back into place after the new seal goes in?
Zachary Hoyt
02-04-2013 17:13:31
 Re: Need advise to get bearing out in reply to paul shuler, 02-04-2013 16:18:18
They will tap back in with a mallet or a hammer and a block of wood.
