| Farmall & IHC Tractors Discussion Forum |
Topic: Need advise to get bearing out
[Return to Forum]
| Author |
[Modern View]
| Paul Shuler
02-04-2013 11:40:07
69.71.1.1
  I am in the process of replacing the inner and outer axel seals in a 1950 Farmall C. The inner seal {one closest to the bull gear side} has the bearing between me and the seal I need to get to. Tell me the best way to remove this bearing so I dont do something stupid.....again. Amazing how stinky and nasty this rear end oil is. |
| PaulW_NJ
02-05-2013 05:09:42
74.105.19.166
Re: Need advise to get bearing out in reply to Paul Shuler, 02-04-2013 11:40:07
|    Above are some photos of my rebuild of my 240, which I believe has the same rear axle design as the Super C. As everyone has said, the bearing should tap off . . . yours must be up against a burr on the shaft. A gear puller may help ease it off, but I'd really try to find whatever imperfection along the splined end is causing the hang up before I apply too much lateral force on that bearing. You'll need a smooth slip for reinstalling the entire axle, so best to touch up the splines first. Good luck. |
| Dennis K (WA)
02-04-2013 18:41:02
24.21.78.195
| So, you must have gotten them out, right?
I found it a help to file a chamfer on the end of the splines to aid in starting the bull gear back on.
Dennis |
| El Toro
02-04-2013 12:26:54
108.3.143.30
| Can that greasy housing be removed from the shaft in the center? If it can then you would have access to the bearing. Hal |
| Retired Farmer
02-04-2013 12:26:25
207.200.116.5
| Get a block of wood and a big sledge hammer and tap on the outer end of the shaft first. If it is made the way I think it is the inner bearing should drive out with the shaft so you will be able to get to the seal. |
| Dennis K (WA)
02-04-2013 12:24:05
24.21.78.195
| Hi Paul,
Put a block of wood on the floor so you don't damage the splines, stand it up vertically with bull gear end down. Pick it up a bit and drop it on the splined end and the shaft with outer bearing will slide out.
Inside the housing will be full of grease from bearing being greased for many years. Once the shaft is out you can go down through the housing and drive out the other bearing and then the seal.
good luck
Dennis |
| paul shuler
02-04-2013 16:18:18
69.71.1.1
Re: Need advise to get bearing out in reply to Dennis K (WA), 02-04-2013 12:24:05
| And what is the best way to put the bearings back in? Will i need a press or can i tap them back into place after the new seal goes in? |
| Zachary Hoyt
02-04-2013 17:13:31
50.122.169.86
Re: Need advise to get bearing out in reply to paul shuler, 02-04-2013 16:18:18
| They will tap back in with a mallet or a hammer and a block of wood. Zach |
| Zachary Hoyt
02-04-2013 12:24:04
50.122.169.86
| It looks just like the H and 300 axles I have had apart, only smaller. Now that you have all of the retainers off you should be able to pick it up by the 'ears' of the housing and bump the end of the axle on a concrete floor and it will pop right out. This may not apply for Cs but it sure does look the same. Zach |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
