TractorLinks.com
Show Parts for Model:
Recommended Gasket Material
F4RM@11
02-04-2013 10:57:58
What type and thickness of gasket material do you suggest for the rear axle carrier caps and PTO? What about suggestions on felt for the rear axle carrier caps?
    GASKET, rear axle carrier cap
    GASKET, power take-off oil seal retainer
    WASHER, felt, rear axle
1953 Stage II Super M
CNKS
02-04-2013 18:45:09
 Re: Recommended Gasket Material in reply to F4RM@11, 02-04-2013 10:57:58
I don't make gaskets as they are cheap enough from CaseIH, and I can never get the right thickness anyway. Not sure you can still get the felt, if not use the old one if it is still any good.
sflem849
02-05-2013 04:21:48
 Re: Recommended Gasket Material in reply to CNKS, 02-04-2013 18:45:09
90% of the time that is what I do. When you start working on the MD sometimes you need to take charge and make your own. That or there is that one simple gasket that you forgot to order and you want to just finish. :lol:
CNKS
02-05-2013 08:50:14
 Re: Recommended Gasket Material in reply to sflem849, 02-05-2013 04:21:48
The only gasket not available for the SH and SM (can't speak for the MD) is the one under the belt pulley. I make an occasional one, and generally order gaskets as I disassemble.
David G
02-04-2013 14:50:11
I just bought mine from CIH, looked real nice.
Nebraska Kirk
02-04-2013 14:02:02
The felt you can get from your local CaseIH dealer.
As far as gasket material goes, 1/32" or 1/64" thickness, either will work just fine.
Zachary Hoyt
02-04-2013 12:25:47
Don't know about the felt. I got gasket paper from my local Ace hardware and also from the local independent auto parts store. I just got the sheets that were big enough to make the gasket out of one piece, I do not think the thickness is critical on those applications.
Zach
