TractorLinks.com
Show Parts for Model:
Re: dt 466 main bearings
pete 23
02-03-2013 17:57:24
Do your new bearings have the groove in back side of bearings to direct oil to oil jets. First time I put in a set of mains after they changed to the groove in behind I did a lot of head scratching but IH released a service bulletin explaining the situation. Also, will you crank accept the wide bearing.
pete 23
02-04-2013 10:36:40
 Re: dt 466 main bearings in reply to pete 23, 02-03-2013 17:57:24
I miss spoke, there is not a groove on back side. It has enlongated holes that reach over to the oil jets from the groove on inside. Origial bearigs had offset holes that lined up with oil jets. IH felt by moving all holes to center in line with the groove they increased the bearing capacity. Later they went to a wider bearing also by changing the radi on the crankshaft journals, both mains and rods, except thrust main. Wider bearing will not fit older shafts.
