Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Super C tire tubes
Don Mountain
02-03-2013 16:18:11
Where is a good place to buy tire tubes to fit a Super C Farmall? Its a 11.2 x 36 tire on a 10" rim. I live in Mid-Missouri. Or can stuff like this be bought off the internet?
old
02-04-2013 10:11:05
 Re: Super C tire tubes in reply to Don Mountain, 02-03-2013 16:18:11
Most any good tire store that does tractor tires will be able to get them if they do not have them on hand. Shoot Orchenals probably has them or can get them. You say mid MO so where is mid MO to you me I am at the Lake of the Ozarks
farmallhal
02-04-2013 09:53:03
Don, as noted in the email I sent you the tubes can be found easily almost anywhere. When I put new tires on my Super C I got tires and tubes from Sanders Equipment in Houston, MO. They are a mom and pop operation (he is a retired IHC tech rep) and they had a lot of inventory with the old prices based on what he originally paid for them. If you are going to be down toward Lebanon or in the Houston area you might check with them at 417-nine six seven-3568. As I recall my tubes were thirty some dollars each about three years ago. At the same time my new 11.2X36 4 ply Firestone Field and Road tires were $70 less each then what the local Firestone dealers were charging at that time. Hope this helps, Hal.
uncle henry
02-03-2013 20:59:51
if your super c still has the brass that holes the valve stem to the wheel make sure you/they put it back on my plastic ones last two years
CNKS
02-03-2013 18:39:54
Any dealer that sells tractor tires. May not be in stock, but a good dealer can get them in a couple of days.
gene bender
02-03-2013 17:09:55
Same place you would get one for your car. www.tiretown.com in KC also
Copyright © 1997-2015 Yesterday's Tractor Co.
