One of 2 problems. Bendex gear is a bad or the flywheel ring gear. Some times you can take a file and remove the burrs on the ring gear to help that
There is a new and different starter drive that can help dramatically. if the teeth are 50% or better of the original depth (length not height)it will be way worth trying. Jim
