| Farmall & IHC Tractors Discussion Forum |
Topic: farmall cub govenor
[Return to Forum]
| Author |
[Modern View]
| Joe Lankford
02-02-2013 10:58:40
75.197.138.237
Bought a 1949 cub, it sat for years. Got it running to discover it had no throtle range 1st notch idle 2nd notch wide open, had a miss and bad bearing knock. Rebuilt engine installed a different used govenor started it to discover same throtle promblem. Read alot, adjusted linkage properly,no play in linkage any where. Does the fan hub have anything to do with this?? Any sugestions? |
| screwstick
02-03-2013 10:03:41
174.24.55.76
Re: farmall cub govenor in reply to Joe Lankford, 02-02-2013 10:58:40
| Hey Rusty, it's hard to give suggestions without knowing the whole story with what has happened to the tractor. What I was trying to get across was the idea that there are a number of things that could be causing his tractors issues, and without knowing the whole story, any suggestion would be no more than a guess.
What you do with your equipment is of course your business, but there is no need to modify something that has worked for over 60 years as is. What one person may consider "better", another may look upon as a "disaster". Plus, your suggestion would not work in Joe's scenario. Your problem with the elongated holes would allow the lever to move forward without affecting the actual throttle setting, leaving the tractor at idle until the slack was taken up. Joe's problem is just the opposite, by moving the lever, the throttle goes from idle to full RPM with just one notch.
He has a different problem, and it will require a different solution. |
| rusty wheel
02-03-2013 09:07:23
75.180.23.218
| Hey Screwstick, Lotta questions, no suggestions. Nothing wrong with modifying parts on these old tractors to make them better. It's done all the time. |
| RTR
02-02-2013 22:23:48
98.83.137.182
Re: farmall cub govenor in reply to Pete76NY, 02-02-2013 10:58:40
| Quoting Removed, click Modern View to see
John knows what he is talking about. He is a forum member here and on FarmallCub.com. His advice is something to listen to. |
| john *.?-!.* cub owner
02-02-2013 20:53:41
72.161.150.122
| sounds like it may have the wrong spring or no spring on the arm on the governor. Strength of that springs balances against the governor. |
| screwstick
02-02-2013 20:14:15
174.24.55.76
| When you installed the governor, did you ensure the internal weights were free?
What about the finger plate that pushes against the weights, is it installed and in good shape?
Where did you get the spring that is installed between the governor rockshaft and the throttle rod?
Are the holes worn or elongated as described above?
What about the woodruff key in the rockshaft going into the governor, is it tight or loose?
What, if anything, was done to the carb internals?
What are the exact RPM's at idle and when it goes full throttle?
Before you start cutting and modifying parts, I'm sure there is an easy fix to cure the tractors problems. |
| rusty wheel
02-02-2013 19:48:13
75.180.23.218
| I had the same poblem with my cub. The holes where the spring attaches to the governor linkage was worn allowing the throttle lever to move without moving the governor arm or the linkage to the carb. To solve this condition, I cut the long rod from the throttle lever to the governor in to under the gas tank, and installed a turnbuckle. This made the rod adjustable and when I shortened the length of the rod with the turnbuckle and took all the play out of the rod it works great. |
| RTR
02-02-2013 16:44:08
98.83.137.182
Re: farmall cub govenor in reply to old, 02-02-2013 10:58:40
There is a wealth of knowledge and knowledgeable people over on the FarmallCub.com website as well as here.....only difference is that site specializes in Cubs only. Alot of information over there in the archives. |
| Joe Lankford
02-02-2013 19:05:23
75.197.22.239
Re: farmall cub govenor in reply to RTR, 02-02-2013 16:44:08
| steve alderman
02-02-2013 11:24:54
68.46.65.102
| check to rod that goes from the carb to the govenor you can adjust that |
| Joe Lankford
02-02-2013 19:08:27
75.197.22.239
Re: farmall cub govenor in reply to steve alderman, 02-02-2013 11:24:54
| I adjusted the rod according to the Blue Ribbon IH manuals. Thanks for replying |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
