Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
02-02-2013 07:31:51
My farmall 100 starter gear sometimes locks on fly wheel gear.What is causing this and how do I fix it?
02-02-2013 19:12:31
 Re: starter in reply to tuckaway, 02-02-2013 07:31:51
Thanks for info. I will look and see. Thanks again. Tuck
02-02-2013 11:01:21
There is a new and different starter drive that can help dramatically. if the teeth are 50% or better of the original depth (length not height)it will be way worth trying. Jim
gene bender
02-02-2013 10:01:23
Next time it locks remove the starter and look at the ring gear and you will see the problem.
02-02-2013 08:27:02
One of 2 problems. Bendex gear is a bad or the flywheel ring gear. Some times you can take a file and remove the burrs on the ring gear to help that
David G
02-02-2013 07:38:44
ring gear worn, I turned mine over when chabging clutch.
