TractorLinks.com
Show Parts for Model:
Re: Farmall H
Janicholson
01-31-2013 18:34:37
The stroker crank had to be welded up on an eccentric, then ground round at a greater stroke. My best guess is the diameter might need to be checked with Plastigauge. With the pump serviced, the only things left are the relief valve in the pump, and the bearings in the lower end. Both require removal of the pan to assess. For new it is way low. Did you check the accuracy of the gauge? Jim
