IAtractorKid
Hey guys! My SH has developed a clanking sound at the front of the engine. First guess is water pump...tractor does not run hot or overheat. Fan is nice and tight. Radiator was boiled and block flushed about two years ago and then it sat for about a year (inside). Water pump felt good when I had tractor apart but I did not remove the pump. Can I take the water pump belt off and run the tractor for a minute to see if sound is still present? Has good antifreeze, maybe I just need some water pump conditioner?
Has M&W live hydraulics but I do not think the noise is coming from that area. Hydraulics work and it runs great! Any ideas? Thanks!
