TractorLinks.com
Show Parts for Model:
Re: New to tractors
sflem849
01-31-2013 07:20:58
That push-pull switch SHOULD be right next to the light switch.
James Dotsonj
01-31-2013 08:01:31
 Re: New to tractors in reply to sflem849, 01-31-2013 07:20:58
Yes it is next to the light switch. It looks just like the choke lever. What position does the ignition switch need to be in?
James Dotson
01-31-2013 08:07:25
 Re: New to tractors in reply to James Dotsonj, 01-31-2013 08:01:31
The switch I'm talking about is a key switch.
RTR
01-31-2013 08:17:18
 Re: New to tractors in reply to James Dotson, 01-31-2013 08:07:25
Sounds like the tractor has been modified (cobbled) over the years and is FAR from the original and correct set up. Detailed pictures of the Dash, serial number (plate on front steering housing), and some other info such as alternator or generator and 12 or 6 volt would also help. That tractor should have originally been red; not the yellow/white combo. Yellow/white came along in the mid 60's on a totally new new body style. That is also the incorrect seat for that tractor, so if you don't like it, that's why.
FYI, the choke lever is opposite the start lever and looks the same as the start lever. If you'll follow the linkage from the carburetor choke, you'll see where it goes. But like I said, who knows what has been changed!
We're here to help you!
This post was edited by RTR at 08:22:05 01/31/13.
James Dotson
01-31-2013 08:21:45
 Re: New to tractors in reply to RTR, 01-31-2013 08:17:18
I'm at work, but do know the tractor is 6v.
James Dotson
01-31-2013 11:20:19
 Re: New to tractors in reply to RTR, 01-31-2013 08:24:57
Thanks.
