Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: A little help with 574 hydraulics
warren woodrow
01-30-2013 07:31:20
Be sure no air leaks around the filter . My 584 had a canister cover which sealed to an o ring gasket. Had to take off and put back on several times before it sealed correctly and stopped aerating the hydraulic fluid. Oring has to be oiled and canister cannot turn while the bolt is being tightened.
JTM Nashville
01-30-2013 08:52:09
 Re: A little help with 574 hydraulics in reply to warren woodrow, 01-30-2013 07:31:20
Thank you Warren for the suggestion. I have read about that being a problem and been very careful to seat this cover correctly. Before breaking it down this last time the tractor ran for about 30 minutes after which I pulled the fluid dip stick which did not show any signs of cavitation. Before replacing the lift cylinder O ring cavitation was visable on the stick. I will check the filter cover again while putting the unload/flow control valve back on, perhaps this evening. Then I'll restest as cyrus suggested.
Copyright © 1997-2015 Yesterday's Tractor Co.
