Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Farmall 560 valve adjustment
Janicholson
01-29-2013 18:03:01
Valve Adjust by Jim --- It is simple and fool proof. The process works for all engines with adjustable poppet valves and any number of cylinders. Identifying the valve order is all that is necesary (given in this process for the IH 6 cyl gas).
I do it this way others do a different system. It must be set cold first, so setting it twice (or once) is normal Get the specification.
Set the intake valve on cylinder #1 (Front) when its exhaust valve just starts to open.
Set the exhaust when the intake just closes.
These are the two positions that can be seen at the springs and retainers for each cylinder to be as far away from a lobe on the cam as possible while still knowing where it is.
The order is (front to back EI-IE-EI-IE-EI-IE)
Look at #1 valves, Turn the engine till the Exhaust just starts to begin opening (moves) then adjust the Intake valve. Rotate more until the intake just stops moving after having been open) and adjust the exhaust. Treat every cylinder (pair of valves shown above) the same way, remembering they switch places between cylinders) I put a rag over the ones I have done to keep track of progress, and avoid mixing what I am looking at. Jim
Zjames
01-29-2013 20:31:15
 Re: Farmall 560 valve adjustment in reply to Janicholson, 01-29-2013 18:03:01
Ok thanks for the help. I thought of another question related to the topic. How did you go about turning the engine over by hand? I have not worked on a lot of red. I use a special flywheel tool to turn the flywheel ? Thanks
Janicholson
01-29-2013 21:21:04
 Re: Farmall 560 valve adjustment in reply to Zjames, 01-29-2013 20:31:15
With the plugs out it is usually easy to turn the engine with the fan. Sometimes necessary to push in on the belt while doing so. Another way is to lift one tire and put it in 5th with the TA ahead. That allows easy rotation. Jim
rustred
01-29-2013 21:05:45
i have a crank for that engine, hard to find them.
rustred
01-29-2013 18:37:41
the spec. is .027 hot.
i adjust valves according to the firing order, 1 5 3 6 2 4 and do both valves for that cyl.when on tdc. on compression. this is the way i was taught in class 36 years ago. but lots more to procedure.
