| Farmall & IHC Tractors Discussion Forum |
Topic: Farmall 560 valve adjustment
[Return to Forum]
| Author |
[Modern View]
| Zjames
01-29-2013 17:45:07
174.225.130.160
I want to adjust the valves in my 560 is there a timing pin that I need to make sure it's at tdc? Tia |
| Jim Naden
01-29-2013 21:38:35
12.74.50.54
Re: Farmall 560 valve adjustment in reply to Zjames, 01-29-2013 17:45:07
| Quoting Removed, click Modern View to see
Easy way....
(timing marks on front pulley)
With engine turned to #1 TDC adjust valves (numbered front to back) 1,2,3,5,7,9
Turn engine one revolution to #6 TDC and adjust valves 4,6,8,10,11,12
Best results are obtained with engine stabilized at room temperature. |
| Janicholson
01-29-2013 18:03:01
74.60.94.18
| Valve Adjust by Jim --- It is simple and fool proof. The process works for all engines with adjustable poppet valves and any number of cylinders. Identifying the valve order is all that is necesary (given in this process for the IH 6 cyl gas). I do it this way others do a different system. It must be set cold first, so setting it twice (or once) is normal Get the specification. Set the intake valve on cylinder #1 (Front) when its exhaust valve just starts to open. Set the exhaust when the intake just closes. These are the two positions that can be seen at the springs and retainers for each cylinder to be as far away from a lobe on the cam as possible while still knowing where it is. The order is (front to back EI-IE-EI-IE-EI-IE) Look at #1 valves, Turn the engine till the Exhaust just starts to begin opening (moves) then adjust the Intake valve. Rotate more until the intake just stops moving after having been open) and adjust the exhaust. Treat every cylinder (pair of valves shown above) the same way, remembering they switch places between cylinders) I put a rag over the ones I have done to keep track of progress, and avoid mixing what I am looking at. Jim |
| Zjames
01-29-2013 20:31:15
174.225.130.160
Re: Farmall 560 valve adjustment in reply to Janicholson, 01-29-2013 18:03:01
| Ok thanks for the help. I thought of another question related to the topic. How did you go about turning the engine over by hand? I have not worked on a lot of red. I use a special flywheel tool to turn the flywheel ? Thanks |
| Janicholson
01-29-2013 21:21:04
74.60.94.18
Re: Farmall 560 valve adjustment in reply to Zjames, 01-29-2013 20:31:15
| With the plugs out it is usually easy to turn the engine with the fan. Sometimes necessary to push in on the belt while doing so. Another way is to lift one tire and put it in 5th with the TA ahead. That allows easy rotation. Jim |
| rustred
01-29-2013 21:05:45
69.58.16.5
| i have a crank for that engine, hard to find them. |
| rustred
01-29-2013 18:37:41
69.58.16.5
| the spec. is .027 hot. i adjust valves according to the firing order, 1 5 3 6 2 4 and do both valves for that cyl.when on tdc. on compression. this is the way i was taught in class 36 years ago. but lots more to procedure. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
