Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Headlight gromment
OldMoIron
01-29-2013 16:31:56
I think it would be the spacer, but I wasnt sure exxactly what it was called, thanks
farmallhal
01-29-2013 17:49:57
 Re: Headlight gromment in reply to OldMoIron, 01-29-2013 16:31:56
If you are referring to the spacer it will be steel and about 3/8" to 1/2" or so long with a hole a little larger then the 1/2" stud on your lamp to slide through. The outside diameter is probably around 3/4" or maybe a little smaller (not near one to measure). The spacer goes between the lamp housing and the lightbar clamp with a split locknut and hex nut on the bottom. Spacers are available from about anyone who sells parts for the letter series tractors. Hope this helps, Hal.
Copyright © 1997-2015 Yesterday's Tractor Co.
