Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Differential tooth pattern-not sure what to do
[Show Entire Topic]  [Return to Forum]
Centex Farmall
01-29-2013 15:25:13
166.137.116.15
No matter how you slice it, setting up a used R&P is a pain in the rear. What TV said is all true.
Going by the bottom set of pictures, I don't think you are far off. Hard to get the camera to focus, but it looks like the contact is a little high on the ring gear teeth. I would move the pinion toward the front of the tractor and then take one shim from the non gear side of the differential and put it on the gear side and then run it again. The book calls for the pattern to be showing on the "toe" end of the teeth which is the end closest to the differential. When the teeth deflect under load the pattern spreads across the whole tooth. That's for a brand new set and as TV pointed out, you have wear on a used set. I think the contact you have is ok where it is, just needs to be a little deeper.
The "drive" side of the ring gear teeth is what you have pictured on the bottom two that you added. "Coast" is the other side. More important to check in a road vehicle as tractors don't spend much time coasting.
[Reply]   [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
