Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Touch control overhaul
IH fan
01-29-2013 08:25:22
If you were to mount a loader on the C and use the factory pump, you can vent it. However to vent it and use a loader you need more capacity, so you can add a 45 degree fitting and extend a reservoir above the fill hole, then it needs to be vented. Otherwise it should not be vented.
TWheat
01-29-2013 17:00:07
 Re: Touch control overhaul in reply to IH fan, 01-29-2013 08:25:22
Exactlly what I did on a FEL (2 way cylinders on lift and dump)on a SA. I capped the top of the added pipe nipple, ( 2" dia X 8"), drilled a hole into the side of the cap, threaded it and put in an extention filled with a material similar to what was used on the vent on the Farmall M hydraulic fill cap. Don't fill it full or it will make a mess seeking its own operating level. Once you get the cylinders full, it doesn't take a lot of additional oil to operate it.
RTR
01-29-2013 09:32:00
A "how to" on this would be awesome!! I have several Super A and 140 TC units that I would like to rebuild, but am just initimidated to do so,
