TractorLinks.com
Show Parts for Model:
Re: Touch control overhaul
mkirsch
01-29-2013 05:55:46
The system is not supposed to be vented.
There is so little air space in the system, that you can't put a vent where oil won't leak/squirt out. It'll be a mess.
The reason it blew out the o-rings is because they're OLD, not because of some flaw in the system. New o-rings and it'll be fine for another 50 years.
IH fan
01-29-2013 08:25:22
 Re: Touch control overhaul in reply to mkirsch, 01-29-2013 05:55:46
If you were to mount a loader on the C and use the factory pump, you can vent it. However to vent it and use a loader you need more capacity, so you can add a 45 degree fitting and extend a reservoir above the fill hole, then it needs to be vented. Otherwise it should not be vented.
TWheat
01-29-2013 17:00:07
 Re: Touch control overhaul in reply to IH fan, 01-29-2013 08:25:22
Exactlly what I did on a FEL (2 way cylinders on lift and dump)on a SA. I capped the top of the added pipe nipple, ( 2" dia X 8"), drilled a hole into the side of the cap, threaded it and put in an extention filled with a material similar to what was used on the vent on the Farmall M hydraulic fill cap. Don't fill it full or it will make a mess seeking its own operating level. Once you get the cylinders full, it doesn't take a lot of additional oil to operate it.
RTR
01-29-2013 09:32:00
A "how to" on this would be awesome!! I have several Super A and 140 TC units that I would like to rebuild, but am just initimidated to do so,
