Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 300 progress (a little)
Zachary Hoyt
01-28-2013 19:37:52
Thank you very much. I had wondered about cutting shims but had thought that maybe that would be a sin. I have had both axle housings off to clean and I replaced one gasket that had been leaking. The ring gear is the one that you sent. I have had everything out of the case and cleaned it all out with kerosene and now have begun to put things back. I will post another picture tomorrow once I get the TA housing back on and check the gears. I am hoping that the ring and pinion will line up, but if not I can always take the housing off again. I found that putting the TA back together went a lot faster this time than the first time I did it.
Zach
Copyright © 1997-2015 Yesterday's Tractor Co.
