Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
cast# and Engine serial#
barney stephens
01-28-2013 15:24:30
Is it possible to find tractor serial # if casting # and Engine serial # is available Casting # 10 8 J Engine # faa81088 Tractor serial # plate under seat is missing
CNKS
01-28-2013 18:51:24
 Re: cast# and Engine serial# in reply to barney stephens, 01-28-2013 15:24:30
For a Farmall A, 81088 is a very early 1942. The casting of 10/8/1940 is possible but not likely as the serial and the casting number are about 15 months apart. You might recheck the numbers and also see if you can find casting numbers on other parts, although the A and B did not have many numbers, or so I have read. Perhaps the block got "lost" for a year before the serial was stamped.
neblinc
01-28-2013 18:19:05
On the left side of this page there is a link under Research & Info called Serial Numbers where you can find the year.
Randy
neblinc
01-28-2013 16:16:59
Should be the same unless the engine has been swapped out.
Randy
barney stephens
01-28-2013 18:00:51
 Re: cast# and Engine serial# in reply to neblinc, 01-28-2013 16:16:59
Randy thanks!! would you agree that the tractor is a 1946 year of mfg.The casting # is J which indicates 1946,this I found on the frame between the engine and differential. 10 8 J.Thanks Again Barney
farmallhal
01-28-2013 18:11:48
 Re: cast# and Engine serial# in reply to barney stephens, 01-28-2013 18:00:51
Barney, Your tractor could be a 1941 (J is the code letter for 1940 not 1946) as the cast parts are not installed the day they are cast. Being cast on October 8, 1940 it is most likely that part wasn't mated with others on the tractor for a couple or more months. I have a 1951 Farmall M which has casting dates beginning in October 1950 and running through early March 1951 and the chassis s/n indicates it was an early April 1951 tractor. Hope this makes sense to you, Hal.
barney stephens
01-29-2013 05:37:38
 Re: cast# and Engine serial# in reply to farmallhal, 01-28-2013 18:11:48
HAL; Thanks!!! I might be reading these serial # wrong. On these serial # on the left side of this page 1942 numbers start at 80739 my serial # is FAA-81088 this number is on the engine.When satisfied that the number is correct,is there a chance to have another serial plate made to replace the one that is missing.THANKS!!! Barney Covington county ALABAMA Andalusia/Opp area
