TractorLinks.com
Show Parts for Model:
H Belly Pump Cover
JCR-Michigan
01-28-2013 14:51:42
I have a Farmall H with no belly hydraulic pump. I am restoring this tractor, and need the cover plate used when there is no belly pump. Does anyone know where I could find one? Or can someone send me some pictures of one on or off the tractor so I can make one? I have never seen the cover, so don't know where to start on making one. (I want it to look as original as possible)
Thanks
John
farmallhal
01-28-2013 18:23:44
 Re: H Belly Pump Cover in reply to JCR-Michigan, 01-28-2013 14:51:42
If you aren't going to install a belly pump you need one of the cast variations which are shown in the two photos. That cover in addition to covering up the big hole in the bottom of the torque tube adds significant strength to the tractor to help keep it from breaking the torque tube from an unknown event. I have a couple like the one pictured by Randy (neblic) if that is the way you decide to go. My email is open if interested in one, Hal.
pete 23
01-29-2013 10:46:13
 Re: H Belly Pump Cover in reply to farmallhal, 01-28-2013 18:23:44
I will agree the cast cover adds strength, no problem with that advice. I got jumped all over on one thread when a puller wanted to remove the rear cover of a large frame tractor to reduce the weight and I had the nerve to suggest it also provided strength and stabililty for the final drive.
pete 23
01-28-2013 16:49:15
The plain one is for tractors with no hydraulics, the other would be for a super with live hyd pump as culivator, corn picker etc would have part of the lift mechanism fastened in the slots. I don't think the old mechanical lift cultivators used that but could be wrong on that. You could easily fashion a heavy sheet metal cover as those cast ones are pretty scarce at least they are around here.
Super-H-Mike
01-29-2013 11:01:47
 Re: H Belly Pump Cover in reply to pete 23, 01-28-2013 16:49:15
I always wondered why the funny shape to the casting under the belly pump, anyone have a picture of how an implement used those slots? I always assumed it was to fit some type of tool or lever for installing the pump into the cavity...
neblinc
01-28-2013 16:45:58
Thanks for clearing that up for me :D
Randy
neblinc
01-28-2013 16:21:19
That piece is sure different than what I have?
Which one is correct?
Randy
This post was edited by neblinc at 16:22:16 01/28/13.
D Slater
01-28-2013 16:43:48
 Re: H Belly Pump Cover in reply to neblinc, 01-28-2013 16:21:19
Bottom was for use with some implements on a stage 2 SH. One you picture was standard for a no pump H and stage 1 SH tractor and also a stage 2 SH.
rusticredacres
01-28-2013 15:03:19
John, I have a NOS cast belly cover for your tractor. Here is a picture if interested email meand we can talk or?
