Push Rod for 450 Gas
Anonymous-0
Had a miss in the 450 for a while. Upon lifting valve cover found bent push rod on #1 and stuck valve which may have been caused by broken spring in the distributor and washer binding up?? Will a push rod for a Super M fit as replacement for this 17and 3 eights length Rod. It is all we can find here. Has anyone had any success long term with straightening a bent rod? Thanks for the help Migraine
