TractorLinks.com
Show Parts for Model:
Re: 300 progress (a little)
CNKS
01-27-2013 17:26:27
If you put back the original gears, or if they are a matched pair, use the original shims, if you don't there will be a new pattern and the gears will be noisy -- in other words don't try to adjust them, as has been said by others on this forum. A couple of years ago I replaced all the bearings in my Super A trans meaning a complete disassembly. I didn't like the clearance or backlash and ordered 2 or 3 new shims, still couldn't get it adjusted right. So, I put the old ones back in the original order, and decided not to try to adjust it. Has more then the "new" backlash given in the manual, but has no excessive noise. If none of what I just said does not apply to your situation, it may not, ignore it.
Zachary Hoyt
01-27-2013 17:36:10
 Re: 300 progress (a little) in reply to CNKS, 01-27-2013 17:26:27
The ring and pinion were both somewhat damaged when I opened up this tractor, but I got a good used matched set of gears and the original shims from D Slater. I think the alignment should be okay but I want to check it while I have it open. A couple of years ago I put Super H gears and shafts in my H that I had then and I put the Super H pinion and shims on the original H ring gear. I must have been born lucky because I ran that tractor for another year with no problems or noises from the rear end. I didn't even check the mesh, I just looked at it and thought it looked like it was probably okay.
Zach
CNKS
01-28-2013 19:02:50
 Re: 300 progress (a little) in reply to Zachary Hoyt, 01-27-2013 17:36:10
Nothing wrong with checking it, but after my SA experience I would be very hesitant to change it.
Janicholson
01-27-2013 17:28:48
His Ring and pinion are not original. Jim
