Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 656 Thoughts
ss55
01-27-2013 13:31:05
The tractor and loader both look to be in good condition, but they are not a great match. I'm not putting down the tractor or the loader, just noting things to be aware of.
Were those loader brackets originally intended to mount it on a bigger longer tractor, like a 706 or 856? The right hand bracket by the clutch is held on by one bolt and the left hand bracket has two bolts. It looks like a good heavy duty loader, but it is too far back on that 656. It will be very tough to get on and off the tractor. When you test drive it take the time to climbing on and off it at least 6 or 10 times or more and don't be shy about complaining about it if it bothers you. The seller is already very aware of it and knows that it hurts the selling price.
It looks like there is a HeatHouser/weather break mounting bracket on the tractor's cowl. One would be great for keeping warm while pushing snow, but with that loader you would almost have to leave the left hand door off to be able to get on and off the tractor. You will also have to leave the right hand window open to reach the loader joystick.
How wide is the loader bucket? Can you move the rear tires and fenders out further to get more room to get on and off the tractor? That would also increase the tractor's stability a little.
The tires are older and cracking, but are still usable with the chains. Check that the rear tire have fluid in them, you'll need it with that loader. Check the front pedestal over well. 7.50 wide front tires would be nicer with that heavy duty loader. A narrow front end is OK on a loader tractor, but it will reduce your trade-in value by $500 to $750 less than a WF. Is that the battery on the platform, that will get old very fast.
The loader is probably about about as old as the tractor, it's not a quick-tach loader, Westendorf had some great quick-tach loaders by 1970. With a quick-tach loader that would become a very handy tractor. I'd value the loader at its trade-in value (less than $500?) and negotiate as if you intend to replace the loader in the near future. After you climb on and off that unit for a few months you may want to do that anyway.
Can you get copy of a loader's manual or mounting instructions from Westendorf to see what the original mounting brackets for a 656 looked like? If that loader can be moved forward on the tractor by 6 to 18 inches it would be a much handier combination. You can put an extension on the joystick handle and extend the brakets going back to the rear axle. A welding shop might be able to move the loader for a few hundred dollars. Please confirm that before negotiating on the tractor.
Both the tractor and loader look to be in good condition, they just don't work well together. Good luck and don't pay too much for that combination as it is. What is the asking price?
IAtractorKid
01-27-2013 15:29:15
 Re: 656 Thoughts in reply to ss55, 01-27-2013 13:31:05
As far as I know the loader brackets are universal, because they look identical to a friend of mines that has a WL30 mounted on a 400. If things line up, I would definately look into moving the loader forward 8-12" probably.
Bucket is 7' so probably not much wiggle room on tread width of rear tires. Rear tires should last me years as is but I have a new set in the shed if need be. Not sure if they have fluid or not, its on my list to check. I have about 10 sets of rear wheel weights at the farm...assuming it uses the same weights as an H or M???
This tractor would be used for minor dirt work around my house and plowing snow, I have about a 150yd driveway. Really a little big for what I need but its what I have found with a deal I think would be fair. He is asking $5250 and the 3pt adapters are included but Im hoping to trade straight across for my H, M and SH.
Loading is not on a joystick, thats the shifter you see...not sure why its bent back. The battery on the platform is where it should be from what I have seen on other 656s.
NF does not bother me and I am comfortable with it on a loader tractor although if things work out, I would be on the lookout for a nice WFE and some flotation tires. Will keep you guys posted. Thanks for the input!
IAtractorKid
01-27-2013 17:00:55
 Re: 656 Thoughts in reply to IAtractorKid, 01-27-2013 15:29:15
Along with wanting to know if wheel weights from an H or M will fit the 656, what wide front end would I look for? Will something off an M, SM, 400, 450, 460, 560 or 706 fit? Probably end up with an aftermarket.
cleddy
01-27-2013 14:23:22
As mentioned in a previous post I just put this loader on a tractor and they are quick-tach. You can adjust them forward (12-15"in front of wheel in my case)by telescoping the tubes that go to the axle horns. To mount you drive into it until the hooks enter the horns mounted to the axles with big bolts-Hook the hydralic up and lift the mid section until it goes in the center brackets(2-3/4 bolts on each side) and pin them and then hook the front braces up to brackets in front(4 bolts each). After brackets are mounted dis-mounting is 2 front hooks and 2- 1" pins in center and hydralic hoses and back out. I agree it may not be a good match since loader is so heavy (1500-1800lbs) but I'm sure price is way lower than new.($8000.00/New Westendorf loader only)
I have set up instructions and an advertizement featuring this loader on a 560 IH tractor.
cleddy
Copyright © 1997-2015 Yesterday's Tractor Co.
