Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Identify Hydraulic Pump & Need Some Help - Super A o
IH fan
01-27-2013 09:43:36
Any flat internal surfaces, I'd get some real fine grit, 400 or smaller, wet or dry sandpaper. Put it on the flatest surface you can find, and wet sand them back flat and clean. Any other surfaces, you could mask off the flats and carefully blast them, but I'd try to use soda as it will not cut the aluminum, but should do the oxide. This is what they use with aluminum airplane parts when they restore old planes. Sand would be bad and glass beads not quite as bad as sand.
RTR
01-27-2013 10:05:39
 Re: Identify Hydraulic Pump & Need Some Help - Super A o in reply to IH fan, 01-27-2013 09:43:36
I do have one of those soda blaster guns from Harbor Frieght, and tried it once on some parts. If I remember correctly, it didn't really do a great job, and made a HUGE mess of dust and soda everywhere. It seemed like it was just "blowing" soda everywhere without any power to clean anything. I'm using an 80 gallon heavy duty oil drive compressor that fills up to 175 psi and shuts off.
RTR
01-27-2013 13:39:21
 Re: Identify Hydraulic Pump & Need Some Help - Super A o in reply to RTR, 01-27-2013 10:05:39
Yep. Tried the soda blaster again with the big compressor. Just blew soda everywhere with out really cleaning anything. This is a cub hyd pump I just blasted. You can see the paint, dirt and grease still on it. I flaked off the clump of dirt with a screwdriver and he blaster wouldn't even do it.
This post was edited by RTR at 14:01:11 01/27/13.
Copyright © 1997-2015 Yesterday's Tractor Co.
